Hello guys
I have a vera that is 98% stable
Anyway, I want to add an XBMC so I can control the sound in my room. Either Airplay or from network
I will add like 6 cameras and install a camera recording software to the same computer where xbmc exist.
Cameras are foscam ones.
The thing is, do you recommend installing xbmc and Camera video recorder on the same device?
I will be using the xbmc vera add-on and the xbmc plugin, any problem with both?
I use iSPy as the camera server. I then use Vera to execute custom Luup code on motion/door sensor being tripped:
local status, result = luup.inet.wget("http://192.168.0.100:8080/record?ot=2&oid=6", 5)
The recording then stops after motion/door sensor is not tripped. Motion devices report no motion in about 5 minutes.
local status, result = luup.inet.wget("http://192.168.0.100:8080/recordstop?ot=2&oid=6", 5)
Note - Change the OID to the camera # in iSpy.
I also wrote a small manual plugin for iSpy that exposes the record/stop record in the Vera scene GUI:
http://forum.micasaverde.com/index.php/topic,23164.0.html
I’ve heard others have had success with a camera server “Blue Iris”.
No problems having XBMC and Camera Server software on the same PC…if it’s a fast enough. I have nine cameras with 720p H.264b streams and iSpy runs at 8% CPU on an I7. YMMV.
Cheers!
THANX man
this solves all my inquiries
