Compatible hybrid NVR recommendations?
I’d like to replace my existing NVR with something that would be compatible with Vera. Basically all that is needed is ability for DVR to serve snapshot URLs for each camera. Then Vera sensors may be used to grap images from cameras when needed.
DVR should ideally have analog inputs for (painfully installed) existing analog cameras but also ability to utilise IP cameras. This would solve problems with cameras that don’t seem to have a simple snapshot image URL (e.g. http://forum.micasaverde.com/index.php/topic,16518.msg284390.html#msg284390).
Also alarm input would be useful.
Do any of you have this sort of DVR in use? Looking for recommendations whether these even exist at all.
Hi I am looking at a system as well did you get one that works with Vera?
