comparing specs
I am new to the products and have been trying to research the differences and features of various devices. The vera3 and the veralite seem to have different levels of capability and capacity, but I can only find one reference to that subject. ?E: Veralite has capacity of 70 devices. No mention of the Vera 3 capacity or limits.
Second. The published specs for the two devices do not address the difference in memory or if memory can be added by any means.
Third: I cannot find any link on any vendors pages to access a full manual of either of those devices.
Last: Is Dashboard downloadable or must one purchase a device to get access to the S/W?
Thanks,
Vera Lite. Click the Features & Specs tab. It is recommended not to plan on more than 70 Z-Wave devices, due to memory constraints.
Vera 3. Click the Features & Specs tab. There is no recommended device limit. One should be able to use the Z-Wave network maximum of 232 devices with Vera 3.
Notice that Vera 3 has twice as much RAM(128MB) versus Vrea Lite’s 64MB RAM. Vera 3 also has two USB ports, WiFi, and 4 LAN ports.
There is also a convenient comparison table here.
The specs linked to above do address memory amounts. Memory cannot be added to either device. These devices are closed and not expandable.
The [url=http://support.getvera.com/customer/portal/topics/575100]quick start guides[/url] that come with each device are available on this page, along with the manuals for several of the devices sold in the getvera.com shop.
Manuals for the new user interface and firmware (UI7) are a work in progress, much like the UI itself. However, you can find them here:
http://support.getvera.com/customer/portal/topics/676548-vera-ui7-basics/articles
http://support.getvera.com/customer/portal/topics/677044-vera-ui7-dashboard-navigation---part-1/articles
http://support.getvera.com/customer/portal/topics/695374-vera-ui7-dashboard-navigation---part-2/articles
The "dashboard" is served from a webserver on the Vera device. You must purchase a device to access it.
