In Tasker you go to plugin, then select Authomation HD device, then on the next screen configuration click on the pencil to select your device. Device select your multi switch. Then you can select your button and on or off action. That is the easiest way of controlling a multi switch via tasker
I’m using the Trigger app for Android and I don’t see how to do it. Feeling a bit noobish in this regard - actually a lot noobish :-[ .
Sorry never heard of trigger. As you mentioned former tasker I thought that’s what you meant. Cannot help there i’m afraid…
No worries! I mis spoke. “Trigger” used to be “NFC Task Launcher”. I just fixed my post before. Sorry about the mix up.
