Tried implementing a virtual device based on D_MotionSensor1.xml and get ‘Command failed: No implementation’ upon execution. Any help on what this error is trying to tell me would be appreciated.
I think that means that you don’t implement the action (in your actionList) for one of the defined interfaces in MotionSensor like SetArmed. You get that error when it tries to call it by can’t find a definition.
@drytoast … Thanks for the feedback!!! As a first time virtual device dabbler … where is the “action list” ???
Check out:
[url=http://wiki.micasaverde.com/index.php/Luup_Plugins_ByHand]http://wiki.micasaverde.com/index.php/Luup_Plugins_ByHand[/url]
[url=http://wiki.micasaverde.com/index.php/Luup_Somfy_Walkthrough]http://wiki.micasaverde.com/index.php/Luup_Somfy_Walkthrough[/url]
or [url=http://wiki.micasaverde.com/index.php/Special:AllPages]http://wiki.micasaverde.com/index.php/Special:AllPages[/url] and then all the luup pages.
You can also go to [url=http://code.mios.com/]http://code.mios.com/[/url] and see examples from other peoples plugins.
@drytoast … thanks for the links. I am not trying to write a plugin … but trying to utilize one from the code page - D_MotionSensor1.xml. I believe my problem is not knowing how much of the ‘create device’ tab needs to be filled in. There is a forum entry ( http://forum.micasaverde.com/index.php?topic=2495.0 ) that implies one only has to fill in the UpnpDevFilename field with the appropriate .xml file.
When I create the device I get a motion sensor with ARM and BYPASS functions but get the error when trying to set either button.
Thanks again for your help.
That’s the problem. The D_ files are just interfaces. They aren’t attached to anything real so when you click ARM or BYPASS, it has nothing to send it to. They have to have an implementation. This can be from a plugin implementation (I_ files) or from implementation part of the core vera system (Z-Wave devices, Insteon devices, UIRT, etc)
@drytoast … thanks for your patience and help. If I plug in the “I” file in the ‘Create Device’ tab it gives me an “error: device not ready” when I try the buttons. What I believe is needed is something in writing on how to use the MCV provided ‘Create Device’ tab.
What is it that device is going to control? Normally you use the Add Device button at the top of the UI4 page to add a device. The create device tab/form is more for developers writing a plugin or a plugin that requests that you use that form (and specifies how to fill it in)
UpnpDevFilename is the device file (D_ files)
That file can sometimes specify an implementation file internally. If not, then
UpnpImplFilename is the implementation of the above device (I_ files)
MotionSensor is the interface, where as a Z-Wave Motion Sensor or “MySpecialMotionSensor” are implementations.
K … I am trying to implement a virtual device on UI3 to set a home/away flag and from reading the forum saw that using the sensor .xml would work. I also thought tat one used the ‘create device’ tab to set up a virtual device.
@gry, you are on the right track, but you need to reference an I_* file in the advanced tab of the device you created under the “impl_file” field or in the D_ file using the tag. Unfortunately, I don’t believe there are any good examples included in a stock vera, but you can probably find the ping sensor implementation file if you search these forums.
Yes. You’ll need to create an implementation. Something that has an actionList like:
<actionList>
<action>
<serviceId>urn:micasaverde-com:serviceId:SecuritySensor1</serviceId>
<name>SetArmed</name>
<run>
luup.variable_set("urn:micasaverde-com:serviceId:SecuritySensor1", "Armed", lul_settings.newArmedValue, lul_device)
return 4, 0
</run>
</action>
</actionList>
This tells the system what to do when the person requests that the device is “Armed” or “Bypassed”.
In this case, it simply sets the local value and that’s it. If it was a different kind of security sensor, it could perhaps send info to an Alarm panel instructing it to act but it looks like you just want a simple state variable.
@drytoast & woodsby … thanks for the input. Let me review what I think I have learned -
Questions -
Thanks again
If you want to keep “Arm” and “Bypass”, you don’t need to create a new D_ file. You can use the standard motion/door/window sensor and get the standard UI.
All I’ve worked with is UI4 so someone may need to correct this for UI3 but:
Don’t need to rename D_MotionSensor.xml, its a standard interface for all implementations
See 1 & 3.
In Mios Developers, I have a Luup Files tab where you can download the current files as well as upload new ones such as your implementation file.
So the short of it is:
a. create simple implementation file
b. upload it to the system
c. create your device with the D_MotionSensor.xml as the DevFilename and the uploaded implementation as the ImplFilename.
Hello,
I am debutant. Or I can find the good file I_MotionSensor1.xml to put on my virtual module?
Thank you for your help
