I have received one of these thermostats.
http://www.vesternet.com/z-wave-eurotronic-comet-heating-thermostat
I can not make “modes” working.
I think it is a vera issue.
Note that the German manual is more comprehensive and complete.
Any experience ?
CE
Found a manual in English.
I have only 2 weeks experience and have had one “cant detect device” but who has not had some of these lately.
I can set temp., works ok. But modes seems not to be supported by vera. I wrote to them, but they are of cause quite busy now.
It will change modes if I wake it up right after sending the command, but vera does not store the command until the device wake up.
CE
I have the same problem. When I click “off”, “heat”, “cool”, “auto”, see “Cannot contact device, error code: 1…”
“It will change modes if I wake it up right after sending the command, but vera does not store the command until the device wake up.”
Change the wake up interval to 240. After this time your comet wake up and receive commands.
Thanks I will try it, it is a short time and will cost battery time.
Vera is looking into the problem at the moment.
Regards
CE
Setting wakeup to 240 increase the possibility to “hit” the right time to make it change.
The problem is still that vera does not keep the command until wakeup.
CE
I dont think Vera did anything about this ! ?
