Here is some code i’ve written to push sensors data (or anything from the vera box) to pachube and sen.se in order to graph some values.
At first, you’ll need to create an account and get a apikey.
For sen.se, it’s stil in beta, so you’ll need to ask to participate to the beta before getting your key.
- put the two global functions in ‘startup lua’ in ‘developpers’ widget, one for sending to sen.se and the other to pachube.
for sen.se:
function my_send_sense (feed, value)
local apikey = "YOUR_API_KEY_HERE"
local base_url = "http://api.sen.se/events/"
local method = "POST"
require('ltn12')
local socket = require("socket")
local http = require("socket.http")
local json_data = "{ \"feed_id\": " .. feed .. ", \"value\": \"" .. value .. "\" }"
local response_body = {}
local response, status, header = http.request{
method = "POST",
url = base_url .. "?sense_key=" .. apikey,
headers = {
["Content-Type"] = "application/json",
["Content-Length"] = string.len(json_data),
["sense_key"] = apikey
source = ltn12.source.string(json_data),
sink = ltn12.sink.table(response_body)
note: there is a bug in the current api, so the “sense_key” parameter in headers is not working. We need to pass the api key in the url. I’ve still leaved the header for memory.
for pachube:
function my_send_pachube (feed, datastream, value)
local base_url = "http://api.pachube.com/v2/feeds/"
local method = "PUT"
require('ltn12')
local json_data = '{ "version":"1.0.0","datastreams":[ {"id":"' .. datastream .. '", "current_value":"' .. value .. '"}]}'
method = method,
url = base_url .. feed,
headers = {
["X-PachubeApiKey"] = apikey
you’ll need to create feeds (in pachube) or devices (in sens.se) and setup some parameters (type of data, etc…)
and get a feed ID -
in Vera again, create a scene, triggered by a timer (ex: every 5 minutes) with a lua code like this one :
(in this sample, I get the value of a EZMotion light sensor and send the info to both pachube and sen.se :
-- id of the monitored device
local deviceID = 34
local lightvalue = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", deviceID)
my_send_pachube ("12345", "LightLivingRoom", lightvalue)
my_send_sense("1234", lumsalon)
return true
note1: the values “12345” for pachube and “1234” for sen.se need to be replacer your own feed IDs
note2: in pachube, we can directly provide a ‘datastream’ within the feed, here I’ve used the name ‘LightLivingRoom’ for this feed.
in sen.se, the feed id is directly associated to the ‘datastream’, so we do not need to send the name.
It’s still simple, quick and dirty, but it works.
Next step : write a function wich is able to send multiple values at one time. (to send everything more quickly)
Tom
