[_CODE_] SmartPhone Plugins
[url=http://code.mios.com/trac/mios_smartphones]http://code.mios.com/trac/mios_smartphones[/url]
this is the same plugin available on the MIOS Marketplace; but with the enhancements suggested by [tt]umtauscher[/tt] and [tt]denix[/tt]. Also some reworks of my own. It’s not (yet) updated in the marketplace because of lack of feedback. Please test!
If we add some more device-specific plugins, these might be hosted here too.
Thanks Javier, I’ll try it out.
OK I figured out to click on the Browse Source Tab to download the plug-in. Do you have a link (I looked in the Wiki) or could you provide instructions on how to manually install a plug-in.
Do you have plans to update and upload the plug-in for the Etherrain-8 Sprinkler Controller Plug-in by 325ix??
Thank you
I will try it as well ( on a BB) if someone can point me to the instructions for installing it on a UI2 box
I’d LOVE to try this, but Im one of the folks that is STUCK with the OLD plugins and no matter what I do when I try to download the newer ones from MIOS or try a manual remove and add I get the OLD plugin.
There are a few of us waiting for a reply from MCV, can you help us get rid of these old files and walk us thru an install of this newer one?
thanks!
im in the same boat as myhomeserver, stuck with old plugins nomatter what i do
[quote=“shady, post:2, topic:165688”]Thanks Javier, I’ll try it out.
Thank you[/quote]
http://code.mios.com/svn_public/mios_smartphones
Right click on the “L_sPhoneUI.lua” and select “Save Link As…”
Save the file to your desktop
Go to your mios dashboard and click the “MIOS Developer” Icon
Open the “Luup Files” tab
Click the “Choose File” button at the bottom of that page
Select the “L_sPhoneUI.lua” from your desktop
Click the “GO” button, this should upload the lua file into your mios system
Well, I feel retarded, I followed my own steps above and I am not seeing any change to the motion/temp/light sensors in the smartphone UI… does vera need to be rebooted? I still don’t see the status of these sensors…
Yes I did check the “Restart Luup after upload” checkbox
[quote=“B0SST0N, post:7, topic:165688”]Well, I feel retarded, I followed my own steps above and I am not seeing any change to the motion/temp/light sensors in the smartphone UI… does vera need to be rebooted? I still don’t see the status of these sensors…
Yes I did check the “Restart Luup after upload” checkbox[/quote]
that checkbox doesn’t seem to do anything. yes, you have to restart Luup. Just do any change and hit ‘Save’.
Ok, working now, I don’t feel retarded anymore since the button doesnt actually work…
Am I supposed to be symbols next to the status icons… these symbols show up next to the motion, temp, and light status…
You can see a " \n’… " next to the motion sensor
And there is a " ’ " next to the Light Sensor
Temperature looks ok
screenshot of all 3 attached
great! that’s the kind of typos that i could easily have introduced when restructuring the templates.
can you report in a Trac ticket? (as much of those things as you can find).
no problem, thanks for working on this plugin, ive really been hoping for sensor status in the mobile ui for quite awhile… great work!
is there a way to attach a screenshot to the trac ticket? these bugs are best “shown” and not “told” :wink:
…I guess I can link to a post on the forum for a screenshot
[quote=“B0SST0N, post:13, topic:165688”]is there a way to attach a screenshot to the trac ticket? these bugs are best “shown” and not “told” :wink:
…I guess I can link to a post on the forum for a screenshot[/quote]
just check the “I have files to attach to this ticket”, and it will ask for the files to attach on the next screen
Apparently I have 2 rooms named “Hallway”, when I click on either one of them I get the message “Handler Failed”… I’ll report this on a ticket too. I probably should just not name rooms with the same name, lol.
Im not going to report any more bugs right now because every time I load the smartphone UI new bugs appear and old bugs disappear… very strange… look at this screenshot… the symbols I saw before are now gone, but my “On” buttons are missing and the Light Level is now gone… these symptoms keep on changing when the UI is first loaded but stay consistent between pages in the same session.
Something similar happend to me after making the first changes. It seem MCV is pushing new (or old) versions onto the Vera.
Since there is no way you would know what happened, I disabled internet access for Vera completely via my firewall. I feel this is the only way to get a consistent behaviour.
Now that I have this working and I see temp from my 3-in-1 motion sensor via my smartphone, I would love to be able to add a reading from my fortrezz water/temp sensor.
Can you guys direct me in the right spot to edit the file to pull this data? Right now it shows as Arm/Disarm which is correct, but if you go inside the ADVANCED info of the device, you can scroll down and see the actual temp. These are the cheapest temp devices that I know of and want to get a better reading from my crawlspace and basements, and eventually I’ll wire them up to AC and poll much more frequently.
Thanks for any help you can provide
a bump for a newbie that wants to add his own features since MCV isnt doing it…Can you guys help guide me in the right direction to pull out the temp in my fortrezz to display on my smartphone plugin??
There must be something broken with the plugin installation.
I tried to update my vera yesterday to the reworked sPhone plugin Javier published.
I uninstalled the plugin, uploaded the new lua-file and installed the plugin again. Now all I get is “404 Not Found” when I try to access the smartphone page.
So I tried to roll back to my previous installation, but nothing changed. Regardless what I do “404 Not Found” stays there and isn’t going away.
I am on 989 btw.
Javier, please help!
I don’t know where to start to debug this problem.
Umtauscher
