[_CODE_] PBD - PachuBe Device V0.1 alpha
EOL, unsupported.
Not compatible with MiOS < 1.5.250!
TODO:
  • Test events
  • Implement UPnP action [tt]GetCurrentValue[/tt]
  • document PBD
  • document MiOS bugs (events and floating point numbers etc.)
  • investigate dashboard problems (device size, device name)
  • add support for uploading data
  • add Human Understandable Format for Unix timestamps
Example:
Use [tt]PachubeFeedID 43053[/tt] and [tt]PachubeDataID gas[/tt] to monitor ajlennon’s gas usage. :slight_smile:
Download:
Looks great :slight_smile: I’ll have to get it installed!
Hi Ap15e,
I’ve confused myself. I finally found 10 minutes to install this what with everything else going on.
I’d thought that it was a service to publish Vera variables up to Pachube but it looks like it’s operating the other way around to pull Pachube data down to Vera?
Am I mixed up?
Cheers,
Alex
The current version of PBD imports data from pachube feeds and provides Luup events.
TODO: [...] - add support for uploading data
Aha! So you can set a red light on your USB traffic light when my gas usage goes over the limit :wink:
One of the (many) things I wish I had time for would be a plugin like this that includes the really neat stuff that Chris’ dataMine plugin does.
i.e. a device that can be configured to monitor state changes on variables around the Vera system and then upload those to Pachube or one of the other myriad providers.
Cheers, A
(btw. Did you catch my post on the Z-wave preamble? I’ve got a really nice little CC1110 based system here and it would be great fun if I could sniff the Z-Wave packets and catch the Danfoss LC messaging).
(btw. Did you catch my post on the Z-wave preamble? I've got a really nice little CC1110 based system here and it would be great fun if I could sniff the Z-Wave packets and catch the Danfoss LC messaging).
http://forum.micasaverde.com/index.php/topic,8609.msg61614.html#msg61614
