[_CODE_] GDL - Generic Data Logger V0.9
EOL, unsupported.
Installation:
[tt]http://wiki.micasaverde.com/index.php/Install_LUUP_Plugins[/tt]
Remarks:
[ul][li]Requirement: (external) syslog server (see [tt]http://forum.micasaverde.com/index.php?topic=7288.msg46266#msg46266[/tt])[/li][/ul]
Output:
Jul 29 18:30:11 192.168.x.y GDL_Startup: watching SERVICE:urn:upnp-org:serviceId:SwitchPower1 VARIABLE:nil DEVICE ID:20
Jul 29 18:30:11 192.168.x.y GDL_Startup: watching SERVICE:urn:futzle-com:serviceId:HolidayVirtualSwitch1 VARIABLE:nil DEVICE ID:20
Jul 29 18:30:11 192.168.x.y GDL_Startup: watching SERVICE:urn:micasaverde-com:serviceId:SecuritySensor1 VARIABLE:nil DEVICE ID:5
Jul 29 18:30:11 192.168.x.y GDL_Startup: watching SERVICE:urn:upnp-ap15e-com:serviceId:LSI1 VARIABLE:nil DEVICE ID:24
Jul 29 18:30:11 192.168.x.y GDL_Startup: watching SERVICE:urn:upnp-ap15e-com:serviceId:FCM1 VARIABLE:nil DEVICE ID:26
Jul 29 18:30:11 192.168.x.y GDL_Startup: watching SERVICE:urn:micasaverde-com:serviceId:SecuritySensor1 VARIABLE:nil DEVICE ID:27
Jul 29 18:30:12 192.168.x.y GDL_13_urn:micasaverde-com:serviceId:HumiditySensor1/CurrentLevel: 1311957012 Humidity 62
Jul 29 18:30:15 192.168.x.y GDL_35_urn:micasaverde-com:serviceId:EnergyMetering1/Watts: 1311957015 Appliance_0 256
Jul 29 18:30:15 192.168.x.y GDL_35_urn:micasaverde-com:serviceId:EnergyMetering1/Log: 1311957015 Appliance_0 256,183,868,1311957015,3616
Jul 29 18:30:15 192.168.x.y GDL_34_urn:micasaverde-com:serviceId:EnergyMetering1/Watts: 1311957015 EnviR 256
Jul 29 18:30:15 192.168.x.y GDL_34_urn:micasaverde-com:serviceId:EnergyMetering1/Log: 1311957015 EnviR 256,183,868,1311957015,3616
Jul 29 18:30:21 192.168.x.y GDL_35_urn:micasaverde-com:serviceId:EnergyMetering1/Watts: 1311957021 Appliance_0 249
Jul 29 18:30:21 192.168.x.y GDL_35_urn:micasaverde-com:serviceId:EnergyMetering1/Log: 1311957021 Appliance_0 249,183,868,1311957021,3622
Jul 29 18:30:21 192.168.x.y GDL_34_urn:micasaverde-com:serviceId:EnergyMetering1/Watts: 1311957021 EnviR 249
Jul 29 18:30:21 192.168.x.y GDL_34_urn:micasaverde-com:serviceId:EnergyMetering1/Log: 1311957021 EnviR 249,183,868,1311957021,3622
Jul 29 18:30:27 192.168.x.y GDL_35_urn:micasaverde-com:serviceId:EnergyMetering1/Watts: 1311957027 Appliance_0 250
Jul 29 18:30:27 192.168.x.y GDL_35_urn:micasaverde-com:serviceId:EnergyMetering1/Log: 1311957027 Appliance_0 250,183,868,1311957027,3628
Jul 29 18:30:27 192.168.x.y GDL_34_urn:micasaverde-com:serviceId:EnergyMetering1/Watts: 1311957027 EnviR 250
Jul 29 18:30:27 192.168.x.y GDL_34_urn:micasaverde-com:serviceId:EnergyMetering1/Log: 1311957027 EnviR 250,183,868,1311957027,3628
Download:
[tt]https://docs.google.com/open?id=0Bz4omZm4gYcsMTA3MTQxOGYtYjIwOC00ODYwLWFiNDktZjczZjQzNWE3NWRk[/tt]
History:
V0.2: local scope for variable DevCat_Description
V0.3: new data structure; log unix timestamp and name of device; remove spaces from items;
new parameter ‘TotalRecall’ (1: log all variables for all services as defined in StartupGDL)
V0.4: replace _ with / to separate variable name from service name (variable name may contain _);
remove spaces from service name
V0.5: add support for GWC; fix [tt]S_GDL.xml[/tt]
V0.6: fix URN_GoogleWeather; add temperature for EnviR; add LastUpdate for GoogleWeather
V0.7: add URN_EnergyMetering1 to device categories: DIMMABLE_LIGHT (2), SWITCH (3), HVAC (5),
WINDOW_COV ( 8 ), GENERIC_IO (11)
V0.8: add URN_HaDevice1 to all standard devices, update variables for URN_ZWaveNetwork1,
add DEVICE_CATEGORY_POWER_METER (21), add DEVICE_CATEGORY_INTERFACE (1)
V0.9: add support for UI5
Drilling into the syslog data …
Now for a more down-to-earth approach (for GDL V0.4 or later):
Get a list of all variables logged:
grep GDL_[0-9] my.log | grep -v truncated | cut -d " " -f5,7 | sort | uniq
List all astronomical events (DAD with device id 4):
grep GDL_4 my.log | grep /LastAstro | cut -d " " -f1-3,8
Extract the data for a specific device (id 34) and for a specific variable (Watts):
grep GDL_34 my.log | grep /Watts: | cut -d " " -f6,8 > my.dat
Plot the data (please note the correction for the timezone):
File [tt]my.plt[/tt]:
set terminal png size 1000,400 tiny
set output "Sensor34.png"
set xdata time
set timefmt "%s"
set title "Sensor 34"
set ylabel "Watt"
set key nobox
set key noautotitle
set xtics format "%Y-%m-%d\n%H:%M"
plot "my.dat" using ($1+3600*2):2 with lines
gnuplot "my.plt"
Continued at:
[tt]http://forum.micasaverde.com/index.php?topic=7333.msg46575#msg46575[/tt]
Please ugrade to GDL V0.7.
Thanks for creating the logger, it works well but I’m having one issue and am curious if anyone else has it.
When I have GDL installed and configured (tried V0.6 and V0.7) LuaUPnP reboots a bunch of times whenever I click the “save” button, or reboot the vera (or double arrow).
2011-08-30 18:32:45 - LuaUPnP Terminated with Exit Code: 245
2011-08-30 18:32:45 - LuaUPnP crash
After ~10 minutes it stops restarting LuaUPnP and everything works fine.
Any ideas?
Local or remote syslog server?
Vera V1 or V2?
Firmware version?
How many variables/services?
TotalRecall mode?
Please ugrade to GDL V0.8.
Please upgrade to GDL V0.9.
GDL V0.9 adds support for UI5.
Anything happening on this plugin? I cannot download the code… and it is not in the Apps section in my Vera too… Pity, it looks very promising!
User Ap15e, no longer participates on the forum. He has removed his work when he announced his departure.
  • Garrett
What a shame
Does anybody have the las version of the gdl plugin?
I asked access on the google drive but had no reply
Tx
