Cisco-Linksys WVC2300/PVC2300
Any clue how to set these up? I was able to get my WVC210 up just fine, but the URL is different for these PVC/WVC… The viewing URL is /video.htm
Any ideas? Thanks!
Disregard… I found if I just plugged the /img/snapshot.cgi, it came up.
The defaults that loaded “size, quality” had to be taken out… works great.
Hi Steve
I’m having trouble registering the pvc2300 as an IP camera, I can get it as a device but can’t seem to make it appear as a IP Camera. Are you able to share what you did?
Thanks in advance…
I think you probably need to have the generic camera plugin installed…
Hi, many thanks
I had a play, in the end I (think) I have got it installed via the ‘Add Device’ and select upnp IP camera
That seems to have done it…
Good to know :slight_smile:
