Example:
My Philio PAN04 creates 4 devices in the vera UI. I’m able to move every device to a different room.
When I edit a device or add a device every child device moves to the same room as the parent device.
Is this a bug or working as intended?
These are probably ‘embedded’ devices, intended to stay in the same room as the ‘parent’ device. Whilst the interface may allow you to apparently move them individually elsewhere, a restart will have them move back to the original place.
In UI7, you can set the variable ‘ChildrenSameRoom’ to ‘0’ (on the parent device)
Forget to mention I’m on UI7. So Vosmont solution did the trick.
This helped me too, thanks!
This also helped me, thanks!
