Cheapest way to get 3-way non-white switches with LED on/off indication
Hello!
I’m not able to find the answer to this problem and figured I’ll finally ask.
I need 3-way switches. I would want BOTH of them to have LED indicator for turned on/off light (say, when lights are ON, indicator is ON / OFF and vice-versa). And I’d really want them to be non-white color and non-default looking).
What’s the cheapest way (if any) to achieve such configuration?
To first problem (LEDs on both of the switches) the solution would probably be using 2 normal z-wave switches (and not normal + add-on) or using 1 scene controller + full switch or using 2 scene controllers + z-wave relay.
But I don’t really want to pay for 2+ z-wave modules where I need just one.
To second problem (custom look), one way to solve (and more universal) it would be using some in-line switch like “Aeotec Z-Wave Micro In-Wall Appliance Switch” (http://www.amazon.com/gp/aw/d/B008VWAPU4/ref=redir_mdp_mobile?ref_=pd_sim_sbs_hi_2) + normal switches. This will add much greater diversity to the look of the switch. But: I would very likely not have any indication of the light turned on (micro switches don’t have indicator output + normal switch won’t have the LED). And there’ll still be 2 of these micro-switches involved which are not cheap.
I hope someone will prove me wrong :slight_smile: Are there any non-white z-wave switches available? Is there a micro switch which can provide indicator output and are there switches which can be connected to it?
Thanks in advance!
Though I have no clue what you are wanting when you say “non-default looking”, several Z-Wave switch manufacturers in the U.S. offer colors other than white.
Most all manufactures REQUIRE special remote/auxiliary switches in 3-way circuits. In most cases you CANNOT use two “normal” Z-Wave switches in the same circuit.
The cheap that you seek is unlikely to be found in any Z-Wave device(s).
If I had an absolute requirement for an LED indicator at a non-Z-Wave switch, I would use a microswitch with whatever wall switches you like and run some additional wiring for powering an LED from the load side of the microswitch. This is very doable if you can run the wiring and know what you’re doing.
Thank you for reply!
Though I have no clue what you are wanting when you say "non-default looking"
You're right, I should have been more specific. Indeed, I'm looking for color other than white (gray, for example). But I'm also looking for different shapes. From what I can see, (almost) all of z-wave switches have the same shape of rectangular button and are white or ivory. [b]Would you be able to point me to any z-wave switch of different form/color? [/b]
And I should also probably have said that I’m in US and looking for products available in US.
I understand that this is less redundant and is obviously cheaper than two separate full z-wave siwtches. But I don't see any technical reason for not being able to use 2 normal z-wave switches where one is just not connected to load a and is controlling second one via z-wave. I may be wrong, of course. Anyway, I likely won't go this route.
I understand that z-wave devices are not very cheap. I'm just looking for the cheapest possible way to achieve what I want. Obviously, this could not possibly be any cheaper than using at least 1 z-wave switch. And likely will be more than that considering my custom asks.
Yeah, that is a good idea, I just wanted to avoid any custom wiring. But if it's the only way, I will consider it. The problem (other than wiring itself) I see here is how would I expose LED from non-z-wave switch? [b]Are there switches with built-in LEDs I could try to attach to?[/b]. Manually added LED will likely not look nice.
I use the leviton vizia RF+ switches. Pricey but they work well.
I use a master switch VRI10-1LZ (1000W dimmer) for the master and then I have too slave remotes VP00R-1LZ (allows dimming control at the remote locations as well). Of course you can also control the lighting via Zwave from Vera.
Both the master and remotes have LED indicators.
Indeed, I did not notice that before. Leviton also has color-changing kits including red/black/gray (for addidional pice).
Thanks!
