Cheapest compatible dimmers?
I am looking to replace my current dimmers and the prices seem to vary a lot.
Therefore I am asking which complete dimmer set (EU) is the most priceworthy?
Waiting for your advice!
This?
http://www.eurox10.com/Product/ZWave/PoPP/ZWduw064336.htm
Thanks for your reply.
Yes, that’s a duwi but I think it needs another set to be complete.
Am I right if I need around 100 euro to get a working dimmer?
I use the dimmer plug modules from TKBhome. They are excellent and relatively cheap (up to $48 with free shipping), but are not wall mountable.
http://www.aliexpress.com/product-gs/474470352-Free-Shipping-New-Designed-Z-Wave-Plug-In-Dimmer-Module-TZ67G-Germany-plug-CE-for-Smart-wholesalers.html
if you need a Wall mounted solution, you can control these dimmers with a TZ66D wall switch using group association, although this can double your overall cost.
TKB is planning to release the TZ66DD which is a wall mounted dimmer, you can try to contact them regarding ETA.
Actually I have exactly these sockets and switches. And have very good communication with the company.
The socket was working perfect but I’ve had some issues with the wall switch. I have the wall mounted switch already but they say it’s not dimmable and it does not register as a dimming module in vera.
