Ive been trying to change my network to a wep encryption. The reason is my camera does not connect well to wpa connections( Foscam camera). I have a separate WPA2 network but need to use vera for just the camera right now.
When trying to change the settings using the new UI it does not create a encryption key with a passphrase entered. Anyone else having an issue with this?
I think you are better off getting a camera that doesn’t have to use WEP unless you don’t mind your neighbors watching you through it. Anyway why can’t you just make up your own key if you want to use wep?
