It was a bit dissapointing that when my vera 3 loses power, it also loses the info on the serial port. The ethernet gateway will avoid this I understand.
Last week I recieved my WizNet W5100.
Reading through the “build” part of this website I do have a couple of questions:
#define IP_PORT 5003 // The port you want to open
-Do I need to change this , or leave it as it is? No clue if port 5003 is in use my any of my devices.
-Do I need to remove anything on my vera 3 since I “had” the serial gateway?
-The 4 arduinos which are now included and have a device number, will they still be working ,Or do i have to remove them and include them again?
Done it a couple of days ago , and no issues at all , it was very straight forward.
Just a small issue with powering the nano , using Vinn and ground + 12V, 2A adapter , the nano and ethernet shield didn’t like it. When I power via the USB connector it works fine.
Cor
