Change Vera3 fron internet access to lacal access
I have setup my vera3 to the internet to control my devices. However my internet connection is unstable and often not available. I want to revert to just a local access without internet being involved. As i have already set it up, what is the process to get it set up as a local controller?
You should always be able to access the VERA locally regardless of whether you have an internet connection or not. Sometimes though, the interface takes a very long time to load if there is no internet connection. But usually if you use an app that communicated with the VERA locally, the presence or absence of an internet connection should not make a difference.
