change USB stick dataMine2
Hi!
I’m thinking about changing my USB stick because I can see now I started up in the first place with too little memory, Is there any way I can transfer the data to a new a USB storage and preserve the data and continue logging on a new stick?
Frode
Hi @Frode - if you simply plug the stick into another computer and copy all the data across to the new stick, it should work.
You will need to ensure that the new USB stick is correctly mounted, so as soon as you have plugged it in, hit reload in the Vera web interface and once the reload is complete go to the dataMine2 web interface and it should ask you to select your new USB stick and restart.
Thank you very much @ConstantSphere
