Hi
I have a plug in switch controller as shown here smarthome.com.au/14-appliance-control
It shows up in Vera3 as a binary light using D_BinaryLight1.xml
I want to achieve 2 things:
- Disable being able to turn this off via the web interface (ie just use it to monitor energy usage and status), it can still be switched on/off via the inbuilt switch.
- Have it classified as an appliance switch not a light.
Can anyone assist with how to do this and if it is possible?
thanks
[quote=“smcleod, post:1, topic:173807”]Hi
thanks[/quote]
Searching the forum would help provide you answers to your questions.
There is no direct way of doing this with out getting a little hands on.
Not possible without changing the device type and may cause issues. All relay type switches are setup as a binary light (light bulb).
