I made some virtual switches which trigger scenes.
I now want to use a specific lua code to set some lighting on specific events using an other scene, when this happens 1 of the virtual switches should also change from ON to OFF our reverse.
But when i use this scene to set this button it triggers an other scene, this is not what i want.
So my question therfore is:
is it possible to change the status of a virtual switch without triggering a scene which has this switch as a trigger as well?
But you could possibly accomplish what you want to do using a little bit of LUA programming. For example, setting a global variable that would be checked in the other scene (and abort the other scene as appropriate).
i.e. In the scene that you want the other scene to not run:
gSuppress = 1
in the scene that is triggered:
if gSuppress == 1 then
gSuppress = 0
return false
You should use global variables with caution, since they will disappear everytime Vera decides to reboot.
solved the problem bij using variable conatainer, her i set: variableX → true/false
I can read and set this from all scene’s, the variable container is ‘read only’ for users
