Change status of virtual switch after set time
Evening
I have created a PLEG to turn all lights off using a virtual switch when pressed in off button. Is it possible for the virtual switch to change its status to on after a set period of time?
Rich
[quote=“Rich1983, post:1, topic:179775”]Evening
I have created a PLEG to turn all lights off using a virtual switch when pressed in off button. Is it possible for the virtual switch to change its status to on after a set period of time?[/quote]
VirtualSwitch does not include this facility. You could use MultiSwitch which does have a Pulse mode that will turn a button off after 200ms.
Alternatively, just add a condition and action in your PLEG to do this.
[quote=“RexBeckett”][quote=“Rich1983, post:1, topic:179775”]Evening
Alternatively, just add a condition and action in your PLEG to do this.[/quote]
Hi
My mistake. That’s what am looking for is how to create correct condition within PLEG
Add switch to other position with a delay?
Probably, yes.
If you have a Condition that fires when the VS turns off with Actions that turn off your lights, you could add a delayed Action to the same Condition to turn the VS back on.
Perfect. All sorted now. I done exactly that with a 30 second delay
