Hi I’m new. i have Veralite with UI5. How can I show in ALTUI buttons as shown in normal UI
These looks like new unsupported (yet) device types. Send me as much info as you can on these devices like the device type, the device .json file that they use and i ll see what can be done . Thx
Both are BELKIN WEMO devices. I installed plugin from the plugin store . One is WEMO Power outlet switch other is WEMO Motion sensor. Both files are standard .json files from the plugin.
Device types Please ?
I attached details for the POWER OUTLET SENSOR - http://www.belkin.com/us/p/P-F7C027/
thx, that is giving me the device_type for the switch, but not for the motion. what is the device type for the other device ?
you can have it from the D_xxx.xlm file or in the attribute screen that you shared previously but for the motion sensor device instead , but beware that the value is not fully visible in the screen shot
you can have it from the D_xxx.xlm file or in the attribute screen that you shared previously but for the motion sensor device instead , but beware that the value is not fully visible in the screen shot[/quote]
I found it i think, can you try this one ? ( load and reload Luup ) ,then refresh browser
