I am trying to install a chacon motion sensor CH54741 with my vera lite & rfxtrx plugin (beta 2 version).
When detecting the sensor, it is seen as “RFX Remote L1.1/K” (with the dim/bright/group on/group off buttons), and not as a ARC/Lightning sensor as I expected.
I have captured the rfxtrx output with RFXManager on PC, below the results (house code K, unit code 2)
“On” triggered : 071001014B020150
“Off” Triggered : 071001054B020070
“Chime” triggered : 071001094B080740
Is there a way to have it recognised as a sensor ?
Open the “managed devices” tab, select your device in the table and then change its type. Vera will reload and you will get a motion sensor. Free your Web browser cache after the reload.
It is not possible simply with the plugin.
But it is certainly doable with an additional virtual switch and scenes to update it when the rfx device state is updated.
