[quote=“lingerba, post:19, topic:190482”][quote=“tb001, post:13, topic:190482”][quote=“intveltr, post:12, topic:190482”][quote=“tb001, post:4, topic:190482”]Yep. I’m at CES now–the volume of smart home stuff is pretty nuts. Lots of people integrating with smart things. No mention of Vera–are they here? They weren’t with the big smart home section.
Unlike a lot of others here it seems, I’m a Vera fan. Yes, it’s not perfect and a PITA to set up, but no other system right now gives me the level of automation I can get with Vera. Still, after going through the smart home section, my takeaway was that at some point I’m likely going to end up making a move to smart things. I love the flexibility of Vera and there are a few things I couldn’t do on smart things, but based on what I saw, it seems like this is the platform to put longer term money on.[/quote]
Smart Things seems to operate in much the same space as Vera (Z-Wave, Zigbee and WiFi devices). What would be a compelling reason for you to move to Smart Things now, other than faith in the company?
By the way, does that thing “phone home” to the mothership? I find that entirely too many of the new HA players rely on Cloud based services, or are busy walling their own gardens.[/quote]
I think it is cloud based, yes. The main reason is that this seems to now be the go to platform for new devices when they’re looking at integrating with existing players. Already smart things has native echo. MyQ and rachio integration, all things I would like to have on vera. The MyQ and Echo plugins for vera are great, but because there is no formal partnership, I never know if I’m going to wake up and find out I can no longer use vera with MyQ. Vera has really lagged on partnerships and it’s hard to see how they can compete longer term with a samsung company… At the very least, I can see setting up some sort of functional bridge between the two controllers to leverage all of the devices smart things is/will be able to support.[/quote]
I have emailed Vera about this subject and by their responses, I really don’t think they understand what I am asking for. My email focused on IFTTT because it seems like if Vera was partners with IFTTT, Vera could be integrated with many other devices regardless of whether they were directly partnered with Vera or not. They claim it would require a full UI rebuild in order to make this happen…?
I was trying to ask when Vera would officially partner with these various companies and not rely on backwards-engineered apps that users created. They responded telling me to use the apps from the store. So I replied back to them saying that I don’t think they really understand what I am asking, and I restated the question again. I pointed out several manufacturer’s websites that list all of the HA systems they are partners with and how none of them included Vera (i.e. Honeywell, Nest, IFTTT, Echo, etc.). I have not received a reply.
I used the Honeywell thermostat plugin as a perfect example of the concern you pointed out. (If you are not aware, the current version of the app store doesn’t work and the original programmer no longer uses Vera. Since neither Vera nor Honeywell support the the plugin has not been fixed. However some people are working to fix it right now). So your concern regarding MyQ is very valid.[/quote]
Yes, this is my biggest issue with Vera. We’ve been hearing that IFTTT support is coming for ages and just waiting on them, but for some reason Vera has been unable to close the deal and get these partnerships done. It’s happened more than once that a plugin has been abandoned by the developer–luckily usually someone steps in and gets it going again, but what happens when the company with the closed Api shuts off access…
Again, I’m happy right now with Vera and smart things has some of the same issues. Last I checked their lutron plugin wasn’t updated for the newer systems and no one could tell me if it would work. And since they’re partnered with Insteon, IIRC, there’s no real motivation to get lutron plugin working. So issues with smart things as well, in part because of their partnerships. Hopefully there will be more pressure put on the manufacturers of products to have open APIs and Vera will step up and start to put more energy into maintaining and developing apps.
Honestly, I think Vera is a fantastic deal given the integration capabilities it has and the ongoing backwards support. It’s a small fraction of our overall spend on HA. My biggest frustration is that I would spend significantly more for a great product experience that has easy native integration and conditional logic. I was hoping we’d get that in one of the newer versions… Or at least a better App Store experience where developers were financially incented enough to stick around.
