Can't seem to get GC-100 to work with custom device files.
I’ve successfully grabbed and tested the On/Off code for my Marantz ZS5300.
To use it via Vera, I’ve followed the steps outlined at: http://tech-n-life.com/index.php/2013/12/3337/ , http://forum.micasaverde.com/index.php?topic=26621.0 and http://www.vesternet.com/resources/application-notes/apnt-68#.VUVlCc5aj4R.
When going to vera_ip/data_request?id=lu_invoke and selecting the IR device, I don’t have the section urn:a-lurker-com:serviceId:Marantz_ZS5300. The only thing that comes up is the urn:micasaverde-com:serviceId:HaDevice1 section, and when I select any of the items listed on there (such as Poll), it returns: ERROR: Device not ready.
The D, I and S xml files are here if anyone cares to take a look: Dropbox - Error - Simplify your life
I’m using UI5 on a Vera Lite.
Thanks for any help :slight_smile:
I could not get anything to work, I had spaces in my actions. Once I got rid of the spaces everything worked. Maybe try changing the action Global On Off to GlobalOnOff and see if that solves the problem. It took me a long time and a lot of trying until I found that.
