Just bought and set up Veralite with door, Nest and light switches in vacation home. Everything was working fine when I left yesterday. Logged into MiOS today, from a different state, and I cannot “see” any of the devices. I have a separate Dropcam camera not in the system and it works fine, so now internet issue. The Overview screen lists the devices, but nothing on Dashboard or when I click on Security, no Yale lock visible.
The Dashboard’s pinned devices section only lists devices that are manually “pinned” in the Devices tab. The Devices tab otherwise shows everything regardless of pinning or classification. My experience is that Vera’s automated classification of devices is not otherwise perfect and so your lock may be elsewhere.
Make sure that your are not in “Pinned Devices” tab. The first page you see when you logged in is that tab. Only the once that you have pinned will appear there. Everything should appear under “Devices” section.
Thanks to all for your responses. I gave up at work on a PC and logged in at home, MAC. Everything was just the way it was suppose to be. Via Dropcam, I wa able to turn on lights and music and watch as the events happened. Sweet system. On to figuring out scenes and triggers.
Thanks again
