New Vera 2 UI4.
I create a new scene. On the Commands tab I set up a command, in this case “turn a light on and leave it”. I go to the Events tab to set up the event, which is another light being turned on. I switch back to the Command tab and it says “no devices”. If I select “Run scene” on the Edit tab it says the scene is invalid.
The only way I can get the Command tab to retain its settings is to select a Room under the trash can, but then if I later change anything on the Commands tab the changes won’t stay in effect even after clicking the Room assignment. Where the heck is the Save button?!?
Creating a scene should be elementary. What’s the secret? ???
