I have several Jasco/GE 46505 receptacles.
The blue LED light default is ON when the receptacle is powered off. It’s BRIGHT! I would rather have the light on when the receptacle is powered on.
The documentation says that:
LED Light
When shipped from the factory, the LED on the 45605 is set to turn ON when the connected outlet is turned OFF. To make the LED turn ON when the light is turned ON, change parameter 3?s value to ?1?.
- Parameter No: 3
- Length: 1 Byte
- Valid Values = 0 or 1 (default 0)
On my VeraLite (UI5) it is not all obvious me me where parameter 3 is located, or how it is named.
Does anyone know?
