can't login on local ip
the i try to login my vera edge on the local ip adres (192.168.2.7) the username and password window pops up,
but when i fill in the username and password the window resets to blank and can’t login ,
only way to log in is via getvera.com
whats wrong here
all help is welcome
You need to disable Secure Your Vera on Unit settings - there is not local access when you enable Secure Your vera
http://forum.micasaverde.com/index.php?topic=30828.0
regards
Harry
thnx harry ,
strange that i didnt find any post about this since it widely discussed topic…
