Can't login Keep getting server busy
Getting very frustrated, I can’t login to unit, keep getting server busy.
Help!!!
Also is there any documentation for help.
Can’t find help anywhere.
Did you try powering it down and back up?
For help your two best sources are the wiki and this forum.
wiki.micasaverde.com
Sent from my Galaxy Nexus using Tapatalk
@snake1950
You can’t login remotely or from the local network?
I have powered it off and on at least 10 times.
The power, Wan and Wireless light come on all green and steady.
Thats it no z-wave light
Tried all the suggested fix’s from this forum-- still no luck.
Tried hitting the reset twice, no luck.
Must be a hard reboot some where??
If you can’t login you can’t fix it.
Is there a back door to login?
Do you get the Data not loading error? If you do, enable Tech Support and send me an e-mail at florin@my.mios.com with the codes.
Thanks I will try it when I get home.
I do get that error. Data Not Loading.
How do I enable Tech Support?
One of the options from that popup window is Enable Tech Support IIRC. If that doesn’t work put this URL in the browser:
http://<Vera_IP>/cgi-bin/cmh/tech_ra.sh
Thanks, Tech support has fied my problem.
It appears that I created an infinite loop that caused the problem.
Whoops!!!
I think that’s what got mine hung up too, specifically the Google Weather plugin. Got in via SSH though and fixed it that way
Help…anyone out there…we’re having the same problem…don’t know anything about a loop. Can’t log in on Micasaverde… What to do???
We have Vera 3…thinking of sending it back. :-[
