Can't get my scene working at 00:00
Hi ,
I am playing with my new vera.
I have a scene that is supposed to run at 00:00 (turn the light off), but it never goes through it.
Should I put 12:00A ?
On another hand, in the scene, there is a “TIMER” text box, what is it for ?
If you want a scene to be activated at 00:00 , you must add a timer to that scene, select which days you want the scene to run and at what time. Then you must setup some commands to happen at 00:00 if you want to see the result of a timer scene.
More info can be found on this page: http://wiki.micasaverde.com/index.php/Timer
Hi ,
I did it exactly the way you are describing. All my scenes work but this one that should be activated at 00:00
I added something else in the timer:
00:00,01:00
and actually, at 1AM it works. It’s just the 00:00 that it does not like. Can someone confirm ?
I have a scene that triggers at 00:00:00 to turn my thermostat down (or up in summer) while we sleep. It runs everyday. I’m on 1.0.988, but I have never had an issue with that trigger on any firmware version.
