Hi
I am new to Veralite and I am trying to get dataMine plugin to work.
I installed the plugin via App->Install App. I plugged in a formatted USB drive to the back of the unit.
I click on the wrench icon under datamine device and hit “datamine graphing page”. It pops up a window with USB configuration. I choose my USB drive and hit save, it comes up with “Please restart Luup (press the Reload button in UI5). Wait a moment before then refreshing the GUI.” I keep restarting over and over but it always does the same thing, asks me for USB drive and then says “Please restart Luup”
What am I missing ?
thanks !!
here is the log:
-1-===========================================================================
06 10/22/13 21:22:37.269 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountUUIDe[0m was: 5A88-45DC now: 5A88-45DC #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 LEAK this:114688 start:774144 to 0x1214000 <0x2ebbb680>
06 10/22/13 21:23:24.118 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountUUIDe[0m was: 5A88-45DC now: 5A88-45DC #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 LEAK this:36864 start:811008 to 0x121d000 <0x2ede8680>
09 10/22/13 21:24:08.936 JobHandler_LuaUPnP::Run device 16 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xcf9130 upnp: 0 <0x2b54a000>
50 10/22/13 21:24:12.793 luup_log:16: dataMine: Initialising dataMine System (0.980) <0x2be7d680>
06 10/22/13 21:24:12.794 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: false #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2be7d680>
06 10/22/13 21:24:12.795 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0xda1a20/NONE duplicate:1 <0x2be7d680>
06 10/22/13 21:24:12.795 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2be7d680>
50 10/22/13 21:24:12.795 luup_log:16: dataMine: Mounting to UUID ‘5A88-45DC’ <0x2be7d680>
50 10/22/13 21:24:13.213 luup_log:16: dataMine: UUID = /dev/sda1: LABEL=“VERAUSB” UUID=“5A88-45DC” <0x2be7d680>
50 10/22/13 21:24:13.230 luup_log:16: dataMine: Found UUID ‘5A88-45DC’ at ‘/dev/sda1’ <0x2be7d680>
50 10/22/13 21:24:13.253 luup_log:16: dataMine: Error reading tmpfile during mountcheck <0x2be7d680>
06 10/22/13 21:24:13.253 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2be7d680>
06 10/22/13 21:24:13.253 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2be7d680>
50 10/22/13 21:24:13.269 luup_log:16: dataMine: Mounting dataMine storage (/dev/sda1) to (/dataMine/) <0x2be7d680>
50 10/22/13 21:24:13.310 luup_log:16: dataMine: Error reading tmpfile during mountcheck <0x2be7d680>
06 10/22/13 21:24:13.311 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2be7d680>
06 10/22/13 21:24:13.311 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2be7d680>
50 10/22/13 21:24:13.327 luup_log:16: dataMine: Mount point error: ::/dev/sda1 <0x2be7d680>
06 10/22/13 21:24:13.328 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: true #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2be7d680>
50 10/22/13 21:24:13.338 luup_log:16: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2be7d680>
06 10/22/13 21:24:13.339 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0xda1a20/NONE duplicate:1 <0x2be7d680>
06 10/22/13 21:24:13.339 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2be7d680>
50 10/22/13 21:24:13.339 luup_log:16: dataMine: Reinitialising configuration structure <0x2be7d680>
50 10/22/13 21:24:13.340 luup_log:16: dataMine: Startup complete <0x2be7d680>
50 10/22/13 21:24:28.161 luup_log:16: dataMine: Delete backups complete - No files found <0x2d07d680>
50 10/22/13 21:24:28.177 luup_log:16: dataMine: Error reading tmpfile during spacecheck <0x2d07d680>
09 10/22/13 21:25:17.217 JobHandler_LuaUPnP::Run device 16 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xc4ec48 upnp: 0 <0x2af93000>
50 10/22/13 21:25:23.717 luup_log:16: dataMine: Initialising dataMine System (0.980) <0x2b8c7680>
06 10/22/13 21:25:23.718 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: false #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b8c7680>
06 10/22/13 21:25:23.719 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0xcf7520/NONE duplicate:1 <0x2b8c7680>
06 10/22/13 21:25:23.719 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b8c7680>
50 10/22/13 21:25:23.719 luup_log:16: dataMine: Mounting to UUID ‘5A88-45DC’ <0x2b8c7680>
50 10/22/13 21:25:24.142 luup_log:16: dataMine: UUID = /dev/sda1: LABEL=“VERAUSB” UUID=“5A88-45DC” <0x2b8c7680>
50 10/22/13 21:25:24.158 luup_log:16: dataMine: Found UUID ‘5A88-45DC’ at ‘/dev/sda1’ <0x2b8c7680>
50 10/22/13 21:25:24.185 luup_log:16: dataMine: Error reading tmpfile during mountcheck <0x2b8c7680>
06 10/22/13 21:25:24.185 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b8c7680>
06 10/22/13 21:25:24.186 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b8c7680>
50 10/22/13 21:25:24.202 luup_log:16: dataMine: Mounting dataMine storage (/dev/sda1) to (/dataMine/) <0x2b8c7680>
50 10/22/13 21:25:24.242 luup_log:16: dataMine: Error reading tmpfile during mountcheck <0x2b8c7680>
06 10/22/13 21:25:24.243 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b8c7680>
06 10/22/13 21:25:24.243 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b8c7680>
50 10/22/13 21:25:24.259 luup_log:16: dataMine: Mount point error: ::/dev/sda1 <0x2b8c7680>
06 10/22/13 21:25:24.259 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: true #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b8c7680>
50 10/22/13 21:25:24.270 luup_log:16: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2b8c7680>
06 10/22/13 21:25:24.270 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0xcf7520/NONE duplicate:1 <0x2b8c7680>
06 10/22/13 21:25:24.271 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b8c7680>
50 10/22/13 21:25:24.271 luup_log:16: dataMine: Reinitialising configuration structure <0x2b8c7680>
50 10/22/13 21:25:24.272 luup_log:16: dataMine: Startup complete <0x2b8c7680>
50 10/22/13 21:25:39.264 luup_log:16: dataMine: Delete backups complete - No files found LEAK this:4096 start:151552 to 0xf33000 <0x2cac7680>
50 10/22/13 21:25:39.335 luup_log:16: dataMine: Error reading tmpfile during spacecheck LEAK this:4096 start:155648 to 0xf34000 <0x2cac7680>
06 10/22/13 21:27:27.265 Device_Variable::m_szValue_set device: 16 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountUUIDe[0m was: 5A88-45DC now: 5A88-45DC #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2dec7680>
-2-===========================================================================
-3-===========================================================================
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,noatime,mode=600)
/dev/mtdblock7 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/dev/mtdblock8 on /mios type squashfs (ro,relatime)
none on /proc/bus/usb type usbfs (rw,relatime)
-4-===========================================================================
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sda: 4009 MB, 4009754624 bytes
23 heads, 22 sectors/track, 15477 cylinders
Units = cylinders of 506 * 512 = 259072 bytes
Device Boot Start End Blocks Id System
/dev/sda1 3 15478 3915172 b Win95 FAT32
-5-===========================================================================
SetDataDirectory-/dataMine/
SetMountUUID -5A88-45DC
SetMountPoint -
SetManualMount -0
-6-===========================================================================
{“dbVersion”:2,“Events”:{“count”:0,“last”:0},“Version”:“0.980”,“Variables”:[],“Graphs”:[],“guiConfig”:[],“nextId”:1}
-7-===========================================================================
