I just had the vera3 installed last night, got the schlage keyless connected and followed instruction to create profile, alert and notification. I got the email testing, but nothing else from the notifications.
I am getting really frustrated now. Can someone please help me? Thank you so much!
Click on the devices spanner and goto notifications. You can add multiple notification for the list and select whom should be notified.
Are you using the Vera Alerts Plugin ?
Can you post the output from the “Report” command.
I have installed the plugin and the app in my android. Vera Alerts will send me test messages and Vera Startup message but won’t send me any notification (I have tried triggers with different devices, have a schlage lock and multiple JASCO light switches).
Any setup video or installation guide?
Help is appreciated
Check:
http://forum.micasaverde.com/index.php/topic,15317.msg168685.html#msg168685
You may not need step 1 or 2 … if you only need 1 user.
Got it working! Many thanks. The issue was that if I didn’t fill in Message Override with the message I wanted, it wouldn’t send the notification.
Now there is one thing I can’t get to work. I have a SCHLAGE lock and I have set up a notification for when a PIN code is entered but I am not getting the notifications. Any one with a similar problem?
You need to enter the pin index into the notification … not the actual 4 or 6 digit pin code.
i.e.
1
2
3
- will notify for ANY pin code.
Great! Many thanks!
