ok im failing at the first hurdle… relatively new to all this, got all my devices setup as i want now so time to start with PLEG… but i can create any triggers… i select the device but none of the dialogs to configure appear… ive tried factory reset,uninstall, reload the apps. multiple browsers… but i cannot fix for the life of me… stil lrunning ui5 btw
On this screen, go ahead and pull down your device and select one. You will then see the screen change to select what type of trigger for your device, you will see a place to name it and you will have to select the detail of the trigger. Then press accept. You have then created a trigger type action.
Do not delete the current PLEG but create another one from the APPS tab. Click on the text Program Logic Event Generator then click Create another. See if this does the same thing.
@Bulldoglowell beat me to it: Do you get the same issue setting a Trigger with a different device (not ID 35)? Can you create a normal Vera scene trigger from device 35?
I fell into the ui6 trap when told to upgrade and successfully downgraded to UI5, as I thought… it appears though that some stuff is left behind. specifically /www/cmh_ui6 even after a factory reset…
So… all the ui5/ui6 capable plugins, including PLEG that check for that directory to determine if UI5 or UI6 see it and setup for UI6… which doesn’t work…
I uninstalled the plugins and deleted all the PL stuff from /etc/cmh-ludl and /www/cmh_ui6, reinstalled and bobs ur uncle, this also caused day_and_night to have similar problems…
I guess I need to see if there is a better way do test for UI5/UI6 …
I did not test … going back to UI5 from UI6. I did not even think of this as a problem … Since you started out by saying you were UI5.
