cant connect to alarm panel (RESOLVED)
Hi everyone,
I have a vista 10SE alarm panel with a AD2USB (SERIAL VERSION) device connected to vera. Everything has been working great until about 3 weeks ago. No status update showing on the UI5 and about 15 minutes later it shows connection down.
I have tried the AD2USB with the Nutech software and it connects with no problem.
I have un installed and installed the AD2USB plugin several times.
Baud rate is set to 115200 as per the instructions
keypad address is set to 31
This is driving me crazy not sure what changed in my setup to cause this. from what i can tell everything is set up correctly and the AD2USB unit seems to working fine
RESOLVED ISSUE
FYI: FOR THOSE WHO ARE USING THE SERIAL VERSION OF THE ADEMCO NUTECH ADAPTER-THE BAUD RATE IS 19200 NOT 115200-CHANGED THE BAUD RATE AND ALL IS WORKING
