Hello,
This will do two days I fight with my camera FOSCAM.
Voila, I installed and connected to the home network
I configured with the application on android (fixed IP: 192.168.0.29)
I managed to make it work with monitoring station on synology with as parameter:
- Ip address: 192.168.0.29
- Port: 888
- Brand: [ONVIF]
- Model: [Generic_ONVIF]
- User: xxxx
- Password: xxxx
on UI7
I did
“Add a camera”
“Generic camera”
then, even in your device I put
Name of camera: camera
Select your camera types: other ip camera
Paste the full URL qui returns a JPG file / snapshot: I do not know what to wear but I tested http://192.168.0.29/snapshot.cgi and it does not work.
Username: xxx
Password: xxx
List network devices
The I do not understand what is happening, the vera list all my devices but no 192.168.0.29 …
However, I have the IP 192.168.0.31 which the mac address of my camera.
I tried with advance ip scanner that gives me 192.168.0.29 with the right mac address
In short, it does not work
If someone had the solution, I ran through many forums but found nothing
In parallel, I will contact the carrier FOSCAM
I’ve had the same problem and never got it working. I tried using the mjpeg sub stream and that didn’t work either. After several attempts on several occasions I just gave up.
Sorry I couldn’t help. If someone posts a solution I might give it another shot.
Thank you for your answer
night helps reflect and I finally ended up finding ;D
In URL, I have try many url (in internet explorer …it don’t work on chrome and firefox)
http://192.168.0.29:88/snapshot.cgi
http://192.168.0.29:888/snapshot.cgi
http://192.168.0.29/snapshot.cgi?user=&pwd=
http://192.168.0.29:88/snapshot.cgi?user=&pwd=
http://192.168.0.29:88/cgi-bin/CGIStream.cgi?cmd=GetMJStream&user=&pwd=
http://192.168.0.29:88/cgi-bin/CGIProxi.fcgi?cmd=snapPicture2&usr=&pwd=
And finally, it is the last one who work
So, if you can’t watch the picture, it is useless to go further
Now, you must do
Add device
security camera
generic ip camera
Next 2 time
Manually install camera
1 Name : what you want but short
2 select camera type : Other ip camera
URL : the url who work for you
3 Fill in the IP address : go down in “list network device” and choose your or any (it don’t change parametre)
4 Fill in the username and password : perform according to its own configuration
click next.
on the next page, if you don’t see an image, it doesn’t matter, you know your url works anyway because previously tested in IE.
I hope it will help you
Now, I want to use the motion detection , who work very great without any false detection, as a vitual sensor
How can i do?
I have join a picture of my parametre
Thank you in advance
