When I keep getting it turning red and saying it can’t configure, is this a distance issue?
What can I do about it wirelessly with a veralite?
(its about 50 ft away through 3 walls), but a door sensor even further away works just fine.
have you tried to z wave heal?
For that specific switch I get Heal: Node 8 0 Good Routes out of 0
I have other switches that work.
You have probably tried excluding and re-including, I’m guessing.
Perhaps the switch is just too far away. You may have to try replacing the switch.
Hm, I did buy it off ebay “new”
I bought a few devices as “new” from ebay in the last few months. They were not “new”, and I had constant problems with them randomly dropping off the network. The date code was 3 years old, and in some cases the packaging was not exactly the same as other ones from trusted vendors.
I now stay with established trusted vendors now .Lesson learned. The $10-$15 saved was not worth the headache.
