I just was forced to upgraded to 1.6 thinking that was the issue Damn it!
Everytime I log in on GetVera remotely, it wants to reinstall Firmware 1.6 and no devices detected After the first install of 1.6, It adds my device. Then when I go to log in locally it says, “Could not find an unassigned Vera on your network. Please click here to help you detect it” When I do that, it again says the device needs the latest firmware again…
However, if I go to the local IP of 192.168.0.11, I can log in to the UI6 interface. What is the issue here???
I didn’t upgrade my router today and I haven’t been able to use the vera mobile app on android. Also, when I try to log into my vera3 with my mios username and password it just hangs then errors out. After the erroring out, I can use my system normally.
I’m experiencing the same thing and I also upgraded my router/modem recently. The app had been working but I didn’t use it for at least this past week. When I tried today, the Vera mobile app on iOS, cp.mios.com and getvera.com all don’t work. Based on the fact that mine had worked well for a couple weeks after upgrading my router, must be a server issue.
I have been able to login to cp.mios.com locally but most of the time it hangs on the loading screen, then an error appears regarding network connection even though it says its connected and my router can verify as well.
I even reserved it's IP via DHCP and opened port 232 with no luck.
Unfortunately I won’t be able to help you much there, I’m hoping not to get in that position myself. I did find a recent thread about reverting firmware: [url=http://forum.micasaverde.com/index.php/topic,23161.0.html]http://forum.micasaverde.com/index.php/topic,23161.0.html[/url]
Everytime I connect to it locally, it says my unit is not assigned to my account, I click to add it, it says it does. Next time I connect to it locally, it says the EXACT same thing
You can downgrade back to UI5.
UI6 uses a different login user and password on a different website. You can’t use cp.mios.com any more. That’s probably your problem.
But upgrading to UI6 has never been recommended on this forum. Even after you get logged in it has other issues and not working with all apps and plugins.
Follow directions on the forum and downgrade before you start looking for another controller. You created this problem but it can be fixed.
I understand the Version 6 uses a different site, that wasn’t the issue. The issue was linking the unit to my account.
Finally figured that out, not sure how but it appears to be working.
I am going to stick it out with version 6 if all my zwave devices work properly. If I new it was Beta, I wouldn’t have upgraded. I just assumed I was way out of date with software as the GoVera site was something I never saw. I assumed that the cpmios.com no longer was valid…
So cpmios is for version 5 and govera is for version 6 only?
Many phone or tablet apps don’t work (some have beta version that do) many Plugins don’t work.
If you only use the Original Vera APP and run no plugins you probley won’t see any limitations then. BUT they are there. You always have the option to go back tho.
