Cannot report bugs via bugs.micasaverde.com, Categoy blank for UI4/UI5
@mcvFlorin,
Looks like Bug filing via bugs.micasaverde.com is down, since you get an error page if you attempt to file a Bug against either UI4 or UI5.
Specifically, fields like “Category”, that are mandatory, have no domain values in the drop down.
Can you arrange to get this fixed? I’d like to formally track every bug I file against UI5, since there’s a lot of issues and they’ll likely fall through the cracks if managed via the forums.
Hi guessed,
I checked now and it seems to work. Can you confirm?
