Hi! I am unable to rename scenes, resp. when I do a new scene it doesn’t save the name, it just says “new scene”. I could name them in the past … I am still on UI4.
Try reloading Vera and renaming them right away …
You may be running out of memory … and if you wait to long … you do not have enough memory to save the changes.
I power-cycled it (hoping that this will reload Vera), but the problem remains the same. I can add as many scenes as I want, I just can’t name them. Also, I only have 5 devices I operate with Vera, so memory shortage should not be a problem (I hope).
Hi Nagyg
What vera hardware platform are you using?
Don
Hi Nagyg
Don[/quote]
I am using VERA 2 with UI4. But since I have left my vacation home I have not been able to reach my VERA anymore and I presume it is dead and that the unability to save scene names were just a first indication of it dying …
