HI,
I’m a new user, and just added the DSC pluggin which works prefectly expect I can’t seem to disarm the system at all.
I can arm it, view all the sensors and they trigger perfectly.
I have already chaged the EnableRemoteArm to disarm, but this didn’t help.
Using UI5 version with firmware version 1.5.408
Anyone hae a solution to this problem.
Ok I have made some progress with this problem.
So I’ve entered the pin code for the alarm system and can disarm from the UI5 interface, but now how do I set up a scene to automatically enter the pin so I can disarm the device remotely?
All DSC panels require the PIN code to disarm, so if you want to scene script it then you need to use the Advanced tab, under the Scene tab, to select the Alarm Partition device.
Once you’ve added this you’ll get a selector for the method, where you choose [tt]RequestArmMode[/tt], and parameters of [tt]Disarmed[/tt], and your PIN value.
