Cannot create another Virtual Switch
I want to have a second Virtual Switch. I went to “My Apps” and clicked on “Create another”, but I did not see another one in my device list. Has anyone created more than one (1) virtual switch? If so, how?
To answer your question, I did, but not recently. I did as you suggest and just used create another device.
It was UI7 but not the most recent.
I dont have that app anymore so can’t re-test.
I restarted the vera and login, and it worked.
Thanks.
[quote=“Mudd, post:3, topic:191646”]I restarted the vera and login, and it worked.
Thanks.[/quote]
Are you using a “MultiSwitch” plugin or you using a single?
Thanks.[/quote]
Standard fix for anything IT. Turn it off and back on again. :smiley:
Unfortunately, there are several devices you cannot create a multiple of. It has been a bug in UI7 that has not been addressed.
But this is not one of them. :slight_smile:
