I have a mobile home that is about 160 ft from the back of my house. In between the two is a tree line (about 35 ft wide).
How far will a Z-Wave network reach?
If the controller is in the house, can I put a sensor in the mobile home or is the distance too far?
Assuming that the two buildings don’t need to have a clear line of sight, but will the trees in between block or degrade the RF signal?
How far would a range extender expand the network coverage area?
Can it be placed outdoors or is it not weather proof?
Thanks!
It is possible that it could reach, there are many variables that affect radio signals. But it is very unlikely that standard Z-Wave nodes will reach that far, through trees, and through walls. Z-Wave signals have a range of roughly 100’ with clear line of sight.
908MHz, the frequency that Z-Wave uses in the U.S. can penetrate trees, but the trees do degrade(attenuate) the signal.
Range extenders have the same range as any other Z-Wave device, but by putting the extender or any Z-Wave node at the periphery of the Vera’s range you extend the coverage area by that same distance again. For instance, if Vera reaches 50 feet and you place a Z-Wave node at the edge of Vera’s range you just added another 50 feet:
Vera -----N)ode -----N)ode-----)
I’ve had no hands on experience with the Aeon range extenders(I presume that’s what you’re talking about), but I doubt that they are suitable for outdoor use. The GE/Jasco 45604 Outdoor Module can be used outdoors and will serve as a Z-Wave repeater or routing node. I do not remember if it supports beaming, a feature necessary for “talking” with locks.
