Can you trigger a scene from a scene? Otherwise I dup scenes for motion sensors
Motion sensors seem to only trigger scenes specifically built for them, which is annoying because I just want them to trigger existing scenes that may be controlled by remotes/switches.
Can you explain better what you are trying to do?
Scenes can have multiple triggers, so you can trigger a scene based on a switch and motion sensor, if either occur than the scene will run.
Ah, I was missing that you can just add multiple triggers.
Cool thanks that solves my issue.
In case anyone is finding this thread looking for the answer, yes you can:
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "168"}, 0)
