Hi everyone,
Can you identify each and everyone one of the z-wave equipment used in this video:
thanks?
Hi everyone,
thanks?
Everspring ST814 Temp + Humi
Everspring SP103 Motion
Aeotec MiniMote
There is also the
Danfoss Living Connect Thermostatic Radiator Valve.
Thanks guys.
What about the yellow and grey boxes with circles? and what about the remotes?
I guess those are vitrum wall switches: http://www.vitrum.com/eng/content/vitrum-i
One of the remotes, as already mentioned is a “Aeotec MiniMote” (which I personally like very much), the other one I guess is a “MK Electric REMOTE CONTROL”.
Go here to see an “almost complete” list of zwave devices: http://www.z-wave.com/modules/Products/
Before buying any of them, check back in in this forum if they actually work with the vera.
I’ve got huge amount of Vitrum devices (well, spent a LOT of money), everything works just perfect - they are so good… Nothing else is even close on the market - for example you could “rotate” touch sensor to set dim level (like old Apple ipods), even 1 LED bulb works fine (it is possible to switch the type of a load which is genious as it not required to install additional resistive load anymore), Z-Wave pairing is just perfect, status report is nearly instant…
In fact, there is no any single issue or disadvantage - except the price.
The only question is how to receive scene buttons from a scene controllers on Vera, I already asked this question from the support.
In the log, I see:
06 11/22/12 0:50:25.416 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:25.417 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545339 now: 1353545425 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:25.419 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:25.420 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545339 now: 1353545425 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:34.596 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 99 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:34.597 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545425 now: 1353545434 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:34.599 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 99 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 11/22/12 0:50:34.600 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545425 now: 1353545434 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
Hi Shapa - did you end up finding out about the scene controller? I have the same problem where any button seems to activate scene “99”. I can have that activate the scene by specifying 99, but, that seems to activate the same scene 99 for every button.
The Vitrum switches look really sweet. Are they EU spec only?
