Can VeraMate manipulate devices?
Can VeraMate change a device status, such as a virtual switch, or a multiswitch, directly? Or is this only possible through a scene?
Thanks,
Tom Williams
I’m not entirely sure what you mean - VeraMate can control most devices. The virtual/multi switches should be supported… though the multiswitch, for example, isn’t the easiest to control - this is on the dev list to have better UI support.
