I would like to know if there is a way we can get vera to contact us by phone in any way when a sensor it tripped. Has this been done?
Yes, it’s been done. Search the forum for “Prowl” for one solution.
Or Vera Alerts for the Android platform.
I have mine alert when my alarm is tripped (armed door sensors etc).
There is a plugin in Vera for Pushover, which works perfect on iOS. I also have mine send an email to my Zapier account and have some triggers in there for calling my phone / sending me a text.
They have a free plan.
Veraalert works very well with prowl must configure the plugin and forward through push notification
see my config Photo
by cons I can not pass a patch event malgr?s Richard
and push notification developer has no idea therefore for messages not worry about the more complicated event and this is a shame because after the name of the event I run a url prowl
if you need more information do I sign
David
by cons I can not pass a patch event malgr?s Richard and push notification developer has no idea therefore for messages not worry about the more complicated event and this is a shame because after the name of the event I run a url prowl if you need more information do I signPlease send me a Prowl Notification using LUA and I will tell you how to do this with Vera Alert Forwarding ... I do not know the details of the Prowl plugin. But if you have an example ... I can translate to Vera Alerts forwarding syntax.
[quote=“RichardTSchaefer, post:6, topic:174765”]
this an an exemple of notification with prowl is
local url = require(“socket.url”)
local when = url.escape(os.date())
luup.inet.wget(“https://prowl.weks.net/publicapi/add?apikey=MY_APIKEY&application=Garage&event=Ouvert&description=Attention+le+Garage+de+Delphine+s’ouvre+” … when … “&priority=1”)
Prowl costs money to download the APP on iPhone yes?
@davidd1205
I was referring to LUA interface to Push Notification for Prowl …
[quote=“RichardTSchaefer, post:9, topic:174765”]@davidd1205
I was referring to LUA interface to Push Notification for Prowl …[/quote]
Ok Richard
Thank you for your job
ok sorry
the good link
luup.call_action(“urn:upnp-org:serviceId:IOSPush1”, “SendProwlNotification”,{ Event= “Garage”, Description=“message”, Priority=2, URL=“”}, 78
thanks
