Comast DNS is out and I am using Google DNS and OpenDNS addresses on my home computers. But Vera is picking up the DNS from my router, which is not working.
Is there any way to force a static DNS into the Vera memory?
If you go to the net and WiFi tab in advanced, select one of the other radio buttons like “Through another gateway on my network. Vera is a switch” and then you get the option to configure it manually.
Thank you!
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
