hi
can I use a “2 port ethernet hub” for vera edge ?
I need 2 ports , one port for network and one port for ethernet gateway !?
[quote=“feredy2011, post:1, topic:191529”]hi
I need 2 ports , one port for network and one port for ethernet gateway !?[/quote]
You can use a Externally powered USB hub. I use a Rosewill RHUB-210 myself just make sure it has it’s own power supply as the edges single port is not powerful enough to power multiple devices.
thank you my friend
