Can I control VeraLite from my cloud-based program
Hi, I have got a new problem.
VeraLite would stop polling the devices after a certain period. I need to reset the polling configuration to make it work, or I have to poll manually by clicking ‘poll now’ button.
The log looks like this:
06 06/21/12 19:27:58.190 Device_Variable::m_szValue_set device: 4 service: urn:upnp-org:serviceId:HVAC_FanOperatingMode1 variable: Mode was: ContinuousOn now: ContinuousOn #hooks: 0 upnp: 0 v:0xa7afa8/NONE duplicate:1 <0x2b2b5680> 06 06/21/12 19:28:51.400 Device_Variable::m_szValue_set device: 4 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 68 now: 68 #hooks: 0 upnp: 0 v:0xa92650/NONE duplicate:1 <0x2b2b5680> 06 06/21/12 19:30:36.103 Device_Variable::m_szValue_set device: 3 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: -3 now: -2 #hooks: 0 upnp: 0 v:0xa74e48/NONE duplicate:0 <0x2b2b5680> 06 06/21/12 19:30:36.133 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusTextwas: OK now: #2: Getting the name #hooks: 0 upnp: 0 v:0xaa1d00/NONE duplicate:0 <0x2b6b5680> 06 06/21/12 19:30:46.731 Device_Variable::m_szValue_set device: 3 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: -2 now: -3 #hooks: 0 upnp: 0 v:0xa74e48/NONE duplicate:0 <0x2b6b5680>
Then it stops polling forever.
Anyone can help me with that?
Thanks a lot!!!
I see.
The setpoint issue was fixed in build 1.5.322, so you would have to update to 1.5.346 to get that fix.[/quote]
Quote
Thanks a lot!!!
@ljcljc
You should contact Tech Support regarding the polling issue.
